| Message |
OK, I have done my homework. Was coming home last Sat, when the AC compressor quit. Didn't lock up (been there already), just quit cooling. I guessed low on freon. Nope, 110PSI static on the gauges and pressure switch is checked closed. I have been through as much of the FSM procedures as I can get to and no dice on anything except that there is no power to the AC relay under the hood. Codes on cimate control show all good. All all fuses, AC and blower in kick panel good, as well as AC fuse in relay box under the hood. No power to the coil or switched poles of the AC relay under the hood, but the damned thing is not on the wiring diagram. Anybody seen this before? TIA.
